More to think about
Jim: I don't exactly agree with some of the responses that you have received so far. When I first got my boat someone recommended a kerosene light to me too. I didn't want another fuel on the boat. I eventually put an Aqua Signal, Series 25, "all-round, pedestal" light on top of the mast. This light does use 10 watts, (.8 Amps), which isn't nothing. Tom's response mentioned a light that uses much less, but it may not be as bright. I bent a channel out of stainless steel and mounted it on top of the mast. The channel is held in place by the pins that hold the pulleys for the halyards. I do sleep much better with a bright white light at the top of the mast. I still always try to anchor in a protected area. I turn the light on at the switch panel. I also have an LED and a remote switch mounted into the cabin light near where I sleep in the V berth. As soon as the sun comes up, I turn off the mast head light. Over this winter I plan on building a sensor to turn the masthead light on and off automatically. I now charge my battery with a solar panel, so I my batteries are always fully charged when we leave for a cruise, but this is another story. Anyway, there are plenty of things to mess with on the boat and to be able to just flip a switch to turn on or off the anchor light seems wonderful to me. Let me mention one other related item. When I ran the wires up the inside of the mast, I cut spacers made from milk jugs that were in the shape of an "X" with a hole in the middle for the wires. I put these about every 2 or 3 feet along the wire and held them in place with wire ties. (The VHF antenna wire ran beside the wire for the mast light). This way I don't have to listen to the wires slapping the inside of the mast all night. If you do this, there is a spacer on the inside of the mast around the bolt that connects the spreader brackets. Mine was very corroded in because the spacer was made from aluminum and the bolt that went thru it was stainless steel (galvanic corosion). I eventually got the spacer out (with plenty of pounding) and replaced it with one that I machined from plastic, as I put the wires in. I'm just pointing out something for you to keep in mind as you plan your winter projects. Before I put the light on top of the mast, I just connected a small 12 volt light bulb with wires soldered onto it onto the backstay above the sail with a clothespin. I still carry this as an emergency anchor light. The power comes from the boat's battery.I hope this gives you some other ideas. Aldo
