So, steaming light failed about a month ago, now that mast is down, boat home,it is time to replace the wire and fixture. With this mission in mind, I promptly cut the wrong plug wires at the mast base so now the anchor light fixture and wires are invited to the party. At the mast top ,the PO had stripped the shielding off the double 16 gauge wires and wrapped the 16 around the bracket into some knots before running them into the fixture. The exit hole at the top of the mast is big enough for shielded cable to come out ,wondering about some kind of clamp, doohickey, etc. to help hold the wire or was P.O. an unsung genius? Photos in daylight , eventually....Calling all Sumners, king of doohickeys ...
