Anchor light type on a Beneteau 331
Jan 10, 2018
264
Beneteau 331 Halifax
Hi all, does anyone know if the anchor light on a B 331 is an LED or regular bulb?
Thanks!
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
Usually your choice! Are you looking to replace it, or just estimate the current draw?
Jun 21, 2004
2,916
Beneteau 343 Slidell, LA
Came from factory with stock incandescent bulb. Possible that a previous owner replaced with LED.
You can replace it with an LED bulb if you wish. Just make sure that it is USCG approved for anchor lite purpose.
I am fairly certain that the light is an Aqua Signal, series 25 classic anchor light, #25000-7 that comes with a standard incandescent bulb, # 175203.
Turn the light on and watch your ammeter. Would tell you what you had.
Beneteau 323 Annapolis MD
Hi all, does anyone know if the anchor light on a B 331 is an LED or regular bulb? Thanks!
Probably dimpled festoon 44mm. I doubt they had LED as OEM back then. Regular unless owner placed LED, which I suggest. I have B323.
