I'm a little emabarassed to ask this question but I can't understand the books I've been reading on this subject. I also would like to understand if my light is wired corectly. This question is directly mainly to other 260 owners. I have a white light at the top of my mast. The control panel switch for this light can be moved to steaming, off (center position), or mast.When the switch is set to steaming, the light cannot be seem from the front but is visible for approximately 270 degrees to the rear and sides. When the switch is set to "mast", the light is visible 360 degrees. According to what I've read, when I'm moving (steaming) under wind or motor power, I should use a steaming light. However, a bridge captain informed me that he could not see me approaching from up river because there was no visible light on my mast.I've been setting the switch to "mast" when at anchor, because I understand an "anchor" light needs to be visible 360 degrees. So if I need the 360 light when at anchor and I need to be visible from the front when steaming, when would I ever need the light only visible from the rear and sides?Do you think the light has been accidentaly rotated by the previous owner? Shouldn't the steaming light at the top of the mast be visible from the front and sides but not from the back? I also have a steaming light just above the transom.
