Conditions & Scope
I just returned from a charter in the BVI's. The boat had an all chain rode and in one harbour we used !all! of it in 40 ft of water! Why? The wind was near 30 knots and the holding wasn't good. We reset twice and drug at 5:1 scope then moved out and just kept dropping chain till there was no more. At that point it held, but I didn't want to sleep there! The water was clear. We could see the chain being lifted from the bottom! It wasn't just dragging. On almost any reasonable bottom, if the shaft of the anchor stays horizontal it will dig in and hold. If the shaft lifts, the anchor drags. Imagine standing on an open dock holding your boat by the anchor rode. You can't cleat it down, you can't wrap the line around a post. Just hold it. That force, applied slowly by the wind, lifts the rode from the bottom until the weight of the rode equals the force of the wind. In a good blow it will lift all of your line, including the chain. If you have enough scope, the pull will still be nearly horizontal even when all of your rode is lifted from the bottom. Then it's just how well is the anchor dug in until it starts to drag. Sure, there are lots of days when 3:1 scope holds fine. On this same recent trip, while snorkeling at the Baths, I saw a boat with less that 1:1 staying in postion. But you could see the drag marks for 50 yards until the anchor hit a rock!Conditions change. Never assume you are anchored safely until you have out at least 5:1 OR GREATER. In some cases where deep water comes in near shore, you do your best, then run a second line to a tree or rock ashore or to a second anchor in shallow water near shore. At Lake Powell in Utah, for instance, the water is so deep right up to the beach and the bottom so hard, some boats don't even bother carrying an anchor cause it's never used. You must always run lines ashore!
