C
Clay
Courious to know what you would set your anchor alarm at:Although I have been sailing for 25 years, I never had all the gadgets.The conditions of the bay were flat like glass with a steady southern wind at 5mph.I set my scope at about 30ft with a 6ft chain & plow anchor attached.At low tide in 5-6 ft of water, expecting another foot within 6 hours, not a problem. Only one other boat swinging with me.At first I set the anchor drag alarm to 10ft., but only had 30 min sleep before it went off. I reset it to 15 ft for another 15min of sleep. The wind was steady out of the south, but I was still swinging left to right. Finally I set it to 40 feet, seemed to do the trick. Although I was clear of the only other boat anchored, I was not pleased with having to set the drag alarm that wide, ESP in 6ft of water with a 30 foot scope..etc etc. I thought of throwing another anchor off the bow to make the "V" that is often talked about to keep you from swinging peacefully, but was to lazy in the dark, I threw it over the port side to a 6ft drop, waited for a swing before I cleated it off there. I set the alarm back to 15 feet and called it a night.
