Amp draw question
Mar 2, 2019
632
Oday 25 Milwaukee
I'm closing in on finally launching our boat for the summer.
We've finally acquired the outboard I've longed for.
An electric start 8 horse ,power trim tilt Yamaha four stroke .
I'm seeing a 40 amp draw when I hit the start button .
Does that sound correct ?
I'm also wondering if using a quick disconnect at the motor will induce an even higher current draw.
Part of me wants to leave the motor bolted onto the back of the boat and hard wire it .
The weight of nearly a hundred pounds really kills my willingness to heft up shoulder level to mount it every spring and fall .
I'm also not sure what that much weight on the far back end of the boat will do to my tongue weight .
I'd like to hear your opinions . Thanks
colemj
Jul 13, 2004
835
40A sounds about right for a small OB starter. Maybe a bit low, but your gauge probably doesn't detect the inrush current.
A good disconnect like Anderson Powerpole shouldn't add any practical voltage drop, so no change in current.
Mark
Tedd
Jul 25, 2013
794
TES 246 Versus Bowser, BC
That's pretty simple to calculate. Measure the longitudinal distance from the axle plane to the motor (motor_distance) and from the axle plane to the hitch ball (hitch_distance).
tongue_weight_change = motor_weight x (motor_distance/hitch_distance)
Example
motor_distance = 10 ft
hitch_distance = 15 ft
motor_weight= 100 lb
tongue_weight_change = 100 x (10/15) = 67 lb
Tedd
Likes: Timm R Oday25
Mar 6, 2008
1,425
Definitely remove the outboard when trailering. The bracket will break when you hit a bump. Ask me how I know.
Quick disconnect with 50 amp contacts are available from a business that sells gulf carts or trailers.
187
catalina C-22 4980 channel islands CA
This is from one of my earlier posts. I do travel with my motor attached to the boat. I have devised a way to use ratcheting tie downs to keep it from bouncing. I used a trailer tongue wieght scale to get the tongue weight to 12% of the total weight.
” I did use a piece of plywood to reinforce the transom. I also had to work out new weight and balance to get the required tongue weight when towing. I added extra batteries under the v-birth and added some weight to the front of the trailer in an ammo can bolted to the trailer near the tongue. I hate to add weight to the trailer but it was the only option I could come up with. The weight in the can is about 50#. This makes it possible to trailer with the motor attached. My motor is the Tohatsu 9.9 Sail Pro purchased new in 2021. It has a carb and about 150 hours on it with no issues. “
Dano
Sep 24, 2018
4,103
Catalina 30 MKIII Chicago
Ive used ratchet straps between the stern rail and cavitation plate to mitigate bounce. Never had an issue with two different boats. My O'Day had 1.5" of plywood in the transom for the motor however.
I have seen instances where moving 100lbs made a difference in towing. You could add weight to the tongue if you're concerned. I'd say try it out and see what happens
May 12, 2025
78
Macgregor 22 Silverton OR
Sailboat data says your boat weighs about 4000 lbs. Rule of thumb says that you should have about 10% of that on the tongue on the hitch when towing on the trailer. It's tempting when loading a boat for a long weekend to pack supplies to the back end of the boat to make it easier to move by hand and not need to put supplies into the boat after getting it in the water. But you run into the same problem of trying to operate a teeter totter with three kids, as it can be done but takes special care. Often a local farm feed store or disposal site will let you run your trailer across the scale to see how much it weighs for free and your own bathroom scale could let you estimate about 300 lbs of tongue weight at home.
Mar 2, 2019
632
Oday 25 Milwaukee
LLoyd , I recently had my trailer weighed at a certified scale . Oday says 4500 pounds . The scale said 7200 pounds ..
I upsized my tires to 1850 pounds per tire . I've found that moving the boat forward to far doesn't let the surge brakes work as they should . Those were mounted to the rear axle . Too much tongue weight and only one axle is carrying the majority of the weight .
May 12, 2025
78
2700 lbs seems a bit high for a tandem boat trailer but I went to sailboat data online to find out the displacement for your boat. So far as placement of brakes on the trailing wheel as opposed to the leading wheel I can see where that could slightly increase the weight downward at the hitch when stopping. How should they work?
Mar 2, 2019
632
Oday 25 Milwaukee
LLoyd . I'm not entirely sure of the thinking behind mounting the brakes on the second axle myself.
I've promised myself one summer very soon , I will replace the surge brakes on the rear axle and add electric brakes to both axles.
Retirement is on the horizon , hopefully it will be one of the first projects that get done .
I trust the scale where I weighed it . Published numbers for the Oday 25 have been in the 4500 pound area.
I can tell you from 20 years of ownership , everything on the boat is heavy . From the mast to the rudder to the outboard to the 6 gallons of fuel .
I'm hoping to weigh the trailer itself this summer
