Scope
I introduced my comment by qualifying it as the "deluxe" setup, to establish one end of the spectrum. I don't understand why "old sailor" has a problem with this, or why he has to argue about it rather than simply present his view. This kind of stuff is what discourages people from contributing to the discussion.Enough is enough, so I'll resign this thread at this point. For the record, my opinion in summary is that:1. All chain on any size boat is the best you can do for a rode. The chain is scaled to the boat size, of course. For example, Acco BBB anchor windlass chain is 1.1 lb. max. per foot in 5/16", but only 0.43 lb. max. per foot in 3/16".2. Abrasion is the worst enemy of an anchor rode. Chain will not abrade on hard bottoms the way rope will. 3. The quality of the anchor set has nothing to do with the type of rode, as far as this discussion is concerned. As long as you have enough chain on the anchor it should set well. 4. The relatively small chain used on these boats is easily hauled by hand if necessary. However, the electric winldass is among the most robust and reliable pieces of gear on the boat, and is useful for other purposes as well, such as kedging if necessary.5. The rope/chain rodes I have for the C36 are precisely the right size for this boat. It's a fairlly light 36 at 6 tons (empty). A good rule of thumb is 1/8" diameter rope per 9' of boat. The chain lead should be at least half the boat length. More won't hurt. So for a 25, 3/8" diameter rope (which is also the practical minimum for handling), and 15' of chain. Chain size should be 1/2 the rope diameter - so in our case, 3/16" (trade size) chain. Do your own research and decide. Here's a good article that also allows you to make calculation sfor your own ground tackle system:http://www.johnsboatstuff.com/Articles/anchor.htm
