Ameriseam bimini
BART FORD
Has anyone bought the 6 ft model? From the pictures in the brochure, when this thing lays down it does so to the back and would make motor access impossible. Can it lay up on top of the cabin?
Patrick Neeley
Ameriseam
I just bought and installed their Bimini for a '93 30' and I have to tell you they did a great job. I am totally satisfied. On the 30' it stows against the split back stays, and in fact there are zippered cutouts for the stays, so I don't have the same problem as you. My major concern was sailing close hauled with the Bimini up, and Jim at Ameriseam assured me it would work fine. It does. I bought the boat last year with an Atwood universal Bimini that would not let me sail with it up. The Atwood also collected 30 gallons of water every time it rained and that wasn't much fun either. I would go for the Ameriseam and live with the Bimini in the stowed position, or leave it up all the time. Good luck.
Bob Schmit
same problem on h26
I think the ameriseam product is great, I have the shorter version and it stows the same as yours and is always in the way when I have to use the motor;in fact I finally took the bimini off the boat-it is in the way more than I use it. I think I've used it 5 times in 5 years.... But is a quality product-just not for this boat.
R. L. Wheeler
Post Ameriseam Contact Info
Could someone post the contact info for ameriseam. The number I have no longer is good. Thanks R Wheeler S/V Rapuzha
Dec 2, 1999
15,184
Ameriseam is on the HOW site.
RL Wheeler: You can contact the Ameriseam company thru the HOW site.
Brian
Keep it up
I also have this prob. You have 2 options: 1. temporarily remove it, if you think you won't be needing it. I don't usually consider this, unless its cool outside and rain isn't in the forecast. its just 2 screws away 2. always leave it attached, even when you don't wish to use it. keep it attached, but in the folded and up position. You can still secure it in both directions. when folded and up, its no more in the way than the boom. brian
Rich Riesmeyer
Quality of the bimini
We have had one on our 23.5 for a few years. We just leave it folded and up when trailering. While it does work just fine, I was disapointed in the fact that it is so baggy around the sides. Did I just get a bad one, or are they all like that? Rich
Tom
Installed one on a 260 this year...
I installed the 6 foot Ameriseam Bimini on my 260 (1999) this year and it works very well. Had to move the main sheet forward on the boom 8 inches to clear the forward edge of the bimini. Over all I am pleased with it and the Ameriseam people are very helpful and responsive. One minor issue I have is that there is no zipper or velcro on the pockets that hold the cloth to the metal support bars. The only way to remove the cloth for cleaning or winter storage is to remove the entire frame from the boat and dismantle the frame. Having shade while sailing in hot summer weather is wonderful. I have been sailing too many years without it, but not anymore! Fair winds... Tom
Tom
Bimini Pictures posted...
I uploaded some pictures of the bimini on Prime Time in the Photo Forum. Fair winds... Tom
C
Charlie Harrell
Ameriseam bimimi contact info
You can also contact Ameriseam at 800 755 7221. I have been to their shop in Tampa and have found all there very good to work with. Good luck
