Hi Again all,Thank you for the replies regarding battery sizes and fitment, location etc. I will reply seperately with regard to that.Regarding amateur radio afloat:
Well my short term aim is to try both a whip mounted on the pushpit and a pseudo backstay made of a suitable wire attached temporarily to the topping lift. For grounding, it has been suggested that I use a trailing wire technique.
Most suitable radio's will have the -ve 12V rail common to the RF ground but it has been suggested to me that the sintered plate or other RF ground that you may use be DC isolated from the boat ground by perhaps several 1000pF capacitors in parallel. Antennas for VHF up operation of course is not a problem.
Operation of most amateur equipment on marine frequencies is illegal, perhaps rightly so. However in the case of an emergency, any form of communication may be justified. Similarly illegal is modifying marine HF radios to cover amateur bands (I understand that an Icom M700 retains its type approval when so modified). Under normal circumstances I would listen to the various HF maritime yachting nets if/when sailing offshore.
Geoff V1619#################################################Geoff Blake, G8GNZ JO01fq: Chelmsford, Essex, UKgeoff@... or melecerties@...
Using Linux: Ubuntu 11.04 on Intel or Debian on UltraSparcand Apple OS X 10.8.2 Mountain Lion on my Macbook Pro. Avoiding Micro$oft like the plague.#################################################
