Jim Rice
The "frames" that pass from side to side, under the cabin sole on my 1980 H27 have drains to let the bilge water run freely between thru the bilge (btw, check your deck drain hoses--'nuff said). There has been some amateur (more amateur than me) patching around them with silicone sealant. And there are some cracks on the fiberglas between the frames--not deep, not weeping, not long. BTW, the keel bolts seem tight and sound OK when Mr. Amateur taps on them.Am I in trouble from 1) rot from water that may have gotten in the frames (ie, is there wood inside, foam forms for the 'glas, etc.) and 2) the cracks. Your help is solicited and any ideas are welcome. An advance thanks to all of you.
