AM FM Radio Interferance
485
Hunter 44 Mystic, Ct
When I am at the dock and plugged into shore power I can not receive any AM or FM stations on the radio even if the main A/C panel breakers are off. I thought the problem was the antenna and purchased a VHF FM splitter and ran the connections over the NAV station to avoid any interference. Was still not able to receive anything. As soon as I disconnect shore power however the radio works fine and I can get all the stations. I have an A/C pro monitor for grounds and galvanic isolator and all indications are normal. Any ideas on how to resolve this issue
Marc P
Charger
Don How are you doing? I am just starting to walk again making good progress. I have a Pro Mariner Charger but I get the interference even with the Main A/C breakers at the panel in the off position i.e. no power to the charger.
Don
Marc
Glad to hear you're finally getting better. I guess I didn't read it thoroughly the first time to understand that it is not the charger although it sounds like it may be your dock neighbors'. The conventional wisdom about RF noise is that it is usually one of two things - on the AC side of the charger so you might want to impose on them to try a little experiment by turning off their AC to see if it helps. Otherwise, it could be the refrigerator/freezer compressor motor. Don't have a clue what else to suspect. Happy/health(ier) NY! Don
