aluminum strip on bow
43
Catalina 27 Kootenay Lake
The bow s aluminum strip was damaged. Cut 2ft section out and sealed the holes. .now what's the best way to bend then reattach the rub rail on my Catalina 27...
Suggestions??...
Oct 17, 2011
2,809
Ericson 29 Southport..
If you've ever done any "tin knocking", this hint would be familiar to you. Attach one screw in the end of the rail, take a rubber mallet, and while putting a little pressure on the other end, start tap, tap, tapping the rail back around the curve. You'd be surprised how much that rail will bend.
And a hundred easy taps, is better than ten hard taps...
