Dwayne Hillier
Hi, I'm in the niddle of rebuilding my (new to me) sailboat. This boat has never had a head before, only a portable toilet. I've purchased a Jabco Manual Head and was going to fabricate my own holding tank. My questions: Is it okay to use aluminum for the holding tank? The holding tank is also only to have 2 openings, correct? One for pump out the other for...pump in, so to speak. Does it matter where these holes are in relation to one another, that is can I locate them based on the straigtest connection to the the head and pump out on deck? Do I need a vent and loop? Since I'm not putting an overboard discharge on the system this is not needed, correct? And finally is it okay to locate the thru hull for the water right next to the head, for eiser access when it is in use?
