Yesterday at the Oakland Strictly Sail show, I spent some time talking to a vendor of anti- corrosion products. And even bought a shaft brush to ensure the best electrical link between my prop shaft from inside the boat and the zinc fish I have been hanging over the side to augment the shaft collar zinc on the shaft in the water. (http://www.saltydoggs.com/product_info.php?products_id=22&osCsid=d768c74d12601789f084aae165683eee). My photo of the device is attached below.
The gentleman also described the benefits of aluminum anodes over zinc. Later, back home, an internet search revealed more info -- mostly in favor of aluminum - even in salt water. (Some links are below.) Seems it's necessary that "aluminum" for anodes be an alloy that contains a small amount of Indium and also some zinc and is manufactured adhering to a military spec. The aluminum anode material is only slightly more active than zinc (-1.10v for Al vs. -1.05v for zn in saltwater against a Silver-Silver Chloride reference electrode), is lighter, lasts longer, and is more environmentally friendly.
My thought is to use the aluminum alloy anode material for my fish anode while at the dock. I would think that being slightly more active than zinc, it might also reduce the depletion rate of my zinc shaft collar anode = fewer times to pay a diver to replace?
Anybody have experience with this aluminum anode verses zinc topic?
http://www.martyranodes.com/content/martyr-resources/alloy-specifications.php
http://www.performancemetals.com/images/pdfs/Aluminum Anodes.pdf
I found that shaft collar anodes are also available in aluminum/indium formulation. http://www.defender.com/product.jsp?path=-1|299255|319700&id=1052567
(Sorry SailboatOwners, but I didn't find aluminum shaft anodes in your store.)
Thanks,
Thanks,
