9 years in my 33.5
I just replaced mine, it lasted 9 years. I went back with another aluminum tank that was coated on the inside. I called the company , Ezell Industries, in Florida who had made the original tank and they still had the Hunter drawings. They made me one that dropped in perfectly.Polyethylene is the way to go if you want it to last forever, but for ease of replacement an aluminum tank with an epoxy coating that drops right in was pretty simple. On the 33.5 all the hoses come out of the top of the tank and is not hard to get to as it's under the u shaped couch around the table. I did not want to re-engineer the set up with a PE tank that had some fittings at the bottom, etc. When you change out your tank plan on changing the discharge hose from the toilet to the tank, mine had a much smaller I D due to all the caked salt/sediment, ie, urine and salt water crystallized.
