Alternator
Robert
I have a Johnson 7.5hp with an alternator. The two wires (black @ white)run inside the hull and stop. Do I connect them to the battery, black on neg. or is there anything else I need to do?
Mickey Goodman
Alternator Hook Up
I had the exact same motor on a Catalina 25 I owned. The alternator wires went to a "block" inside a lazerette which also had attached to the block wires from the battery(s). Black to Black and red to red. Make sure you use a block so that you could easily remove the motor alternator wires from the block without having to distrube the battery wires to the block.
