My two tries
I've done two pulleys for mine. The first was a double pulley from the auto junkyard, about 7" in diameter. I just laid out the bolt pattern by hand and drilled it by hand. It came out more centered than the add on one that came with the raw water pump kit.Later I determined that I needed a bigger one (10") to get more charging at an idle. I bought a big cast one from Grainger (about $50) and had a friend who has a mill drill the holes. It didn't cost much, I think I traded some help doing something for the work. I could have done that one myself, too, but the holes went on an angled rough cast shoulder and I wanted it relieved there. More time spent searching for a pulley that didn't have that problem might have made the mill unnecessary.If you get a new pulley, be sure to get as big as you can so that it will put out more at low speeds. The way to find the ratio is to match the top engine speed (3qm30 is about 2800 rmp) with the top rated alternator speed (varies, but probably 10,000 to 11,000 rpm). It doesn;t help at top speed, but gets it spinning as fast as possible at low speeds.I get about 80 amps at 600 engine rpm now with my 150 amp Hamilton Ferris alternator.Email if you want more details at rainbowchaser@ev1.net
