Randy
I've got a Universal M-18 diesel in my 84 Catalina 27. I'm wondering if anybody can shed some light on the operation of the tachometer after starting the engine. Typically, my tachometer (a Teleflex, which gets its signal from the alternator, a 55amp Motorola, which I believe is original) remains at zero right after starting. It takes a blip of the throttle to get the alternator to kick in, which then immediately starts the tachometer. I'm told that this is normal, and allows the engine to be started without the extra load of an alternator that is "engaged". In fact, this is how my setup has worked since I got it in '99. On my last two starts, (yesterday) the usual blip of the throttle got some response from the tach, but it was not normal--it seemed to be reading low, and moving in slow motion. This lasted less than a minute both times, and then the tach returned to "normal", and gave correct readouts of rpm, and responded instantly to rpm changes. Any idea what could have caused this? Is my alternator on the way out? Or is it something in the tach, or in the wiring in between? By the way, alternator output is still good, giving me voltage in the high 13 range when the engine is on. Thanks for any input.Randy
