I attached the curved bracket at the bottom of the alternator and closed that pivot stud finger tight to make it seat firmly against the engine part. Then I pivoted both the alternator and the bracket, expecting them to mate snugly. Instead, the bracket wouldn't cleat the flange of the alternator and I couldn't make the bracket mate with the hole for the bracket stud. I could swear that was the way it was put together (the only thing I wasn't sure about was whether the bracket stud was installed with the head on the front side and the nut on the backside or vice versa). I spent a lot of time trying to figure out if the bracket was mounted in some other way, but all my conclusions pointed to the way I have it.
The only way to make it fit was to loosen the bracket pivot stud a little so that there would be enough play in the bracket to get it to clear behind the alternator flange. Eventually, that's the way I put it together and then just tightened everything down. It's all very snug and tidy, but I am left wondering if that mismatch was intentional so that there would be compression on the two parts as the studs were tightened down or if I missed something that would make the fit more exact. You can't see the curved part of the bracket in the photo as it is behind the alternator flange. Sorry if my part descriptions aren't technically correct!
Reason's why I loosened my alternator:
1. The belt loosened and I had belt dust all over. I changed the belt.
2. I had to get access to the negative stud to install a new cable going back to the negative bus bar. In the meantime, @Maine Sail (and others) suggested that I shouldn't have 4 AWG cables attached to the alternator studs, so I installed 6 AWG cable running to the top of the compartment. From there, I will run the 4 AWG cables that I already have.
3. I installed a new washer that hopefully will provide a better grip on the alternator bracket. The original washer was significantly thicker than a normal washer, but this new "Grip-it" washer should provide a better grip hopefully!
Finally, with everything in place, with covers in place!
