Jack Betts
I have a 55amp Hitachi alternator that replaced a 35 amp alternator on my Yanmar 3QM30 some time ago. Currently there are two wires connected -- one from the lower part of the back of the alternator, and the other to the lower (and vertical) of two spade-type connectors within a plastic housing. The upper spade connector, which is horizontal, is not connected to anything. Nearby, taped off on a piece of rigid tubing is a brown coiled wire with a spade connector on its end -- but unconnected to anything. I suspect this might have once been connected to the 35 amp alternator, but evidently it was never connected to the 55 amp alternator. 1. Can anyone tell me what this wire might have done on the original h37 with the 35 amp alternator? 2. Can anyone tell me what is the purpose of the horizontal spade connector on the 55amp alternator? 3. Might this wire have been connected to the horizontal spade connector on the alternator?4. And finally, occasionally (perhaps 5% to 10% of the time) my cockpit charge light flickers or glows red briefly. The alternator belt tension seems to be okay. Does anyone have a suggestion what might cause the occasional flickering (and momentary drop in the tachometer reading)? Could that be related somehow to the unconnected spade connectors? Thanks!
