I installed a series 7 Balmar and everything works fine. Except I want to slow it down by about 1/2. The pulley dia on the alternator is 2.5". The diam at the drive pulley is about 13 giver or take. The ratio is 5.9 as measured by a laser tach. Redline for the alternator is 15k rpm. At 2500engine rpm, the alt is going 14750 rpm. Seems to me I need a 5" alt pulley. It would keep alt speeds between 2400 7500 and supplying same performance. The math doesn't work perfectly as there was some rounding...thing is nobody seems to have a 5" pulley for a single 3/8 belt. Even the electrical shops are skeptical.. I would just like to operate it further down on the curve for longevity. Any other issues of a larger pulley such as side loads? Suggestions as to where to source a pulley?
