Alternator on 1996 Mariner 9.9 HP?
David
This outboard came with the boat when I bought it this spring and I was wondering if an alternator was standard with this model or how I could tell if it has one? 1996 Mariner 9.9HP 4-stroke electric start
H
Hayden Watson
Probably
Most outboards that have electric start have the built in alternator. They usually only put out 5-10 amps.
Ray Bowles
David, since your motor is an electric start...
you will probably find in your owners manual that it recharges your battery thru the wires that supply the juice for starting. Probably the charge is around 14.2 volts and 5 amps. Hope this is true and helps. Ray
