Jim Ewing
I talked with the alternator shop and they suggested it might be a bad battery or bad cell in one of the batteries. I disassembled the bank and found one battery with no "idiot light" showing. (They're these Delco maintenance free batteries). There was a bit of growth on the + terminal. All other batteries were OK and clean terminals. Based on what the alternator guy said I think that what happened was that the alternator sensed the corrosion as a voltage drop and continued putting out amps to try and fill the battery. This didn't work and so it toasted the first battery in the bank.I'll be testing this hypothesis but right now it seems to make the best sense. I think what I also might do is put in a distribution bus so that the charge current might be distributed a little more fairly.Jim"Prospect"
