I'm trying to fix the alternator wiring on my Volvo Penta md11c - it hasn't been working since I bought the boat, and I've been recharging my batteries with shore power. The alternator should be charging two 80Ah Sears DieHard deep cycle wet cell batteries.
The alternator is a Delco 63 amp alternator (#1103091) with built in regulator that was wired to something called an Automac alternator controller. I believe the Automac fakes out the voltage sensor on the alternator in order to charge the batteries at a faster rate.
The alternator was connected to the automac via two wires, a 4-guage cable connected to the "bat" terminal on the alternator, and another 12 awg wire that mysteriously comes out of the alternator between the terminal posts labelled 1 & 2. There was nothing connected to 1 & 2 previously. The 12 awg wire was connected to the on/off switch on the Automac, but I believe also gets fed a variable voltage based on a dial you can turn on the Automac.
According to the former owner, the current wiring set up was initially working, but became finicky and then stopped all together at some point. Today, I removed the Automac and tried connecting the alternator directly to the battery, but wasn't sure what to connect the sensor wire to. So I tried to leave the sensor wire unconnected, but the alternator didn't produce any charge. (Should it?)
I then tried to get the alternator tested at PepBoys, but the technician couldn't figure out how to work the testing machine they have.
Tomorrow, I plan to reinstall it and wire the sensor to the ignition key switch and see if that makes a difference. If not, I have a "spare" alternator (possibly also broken) that I will try in the same way. If those both fail, then I'll try to find another auto shop that can test the alternator.
Could anyone with experience in this sort of thing tell me if I'm on the right track or way off base? Also, should I be concerned that there is no ground on the alternator?
