I've just replaced my failed OE Mando alternator with the Compass Marine CMI-72-IR same frame size unit. The adjustment arm was marginal before and definitely won't work with the new alternator. Has anyone found an available bracket that works to swing the alternator farther away from the engine, but not too far? Belt will of course need to be longer, so any suggestions on the bracket + belt combo are appreciated.
The photo shows the alternator folded in as tight as possible. It will be better to get it away from the engine a bit.
Thanks in advance. /Ed
