ALL BOATS! CABIN TOP DAMAGE FROM COMPRESSION POST
G
GERRY FRIG
ALL OWNERS SHOULD REVIEW MY COMMENTS ON SEVERE STRUCTURAL DAMAGE RESULTING FROM WATER BUILD-UP IN THE MAST COMPRESSION POST WHICH THEN FREEZEZ AND EXPANDS FORCING THE CABIN TOP UPDARD AND CAUSING SEVERE DAMAGE. HUNTER CLAIMS NO NEED TO WORY, BUT IF THE WIRING INLET LEAKS IT WILL GO INTO THE POST AND BIULD UP SINCE THEY PROVIDE NO WEEP HOLE IN THE BOTTOM. IF YOU STORE YOUR BOAT IN THE WINTER, YOU SHOULD DRILL A 1/8 TO 3/16 HOLE AS NEAR THE BOTTOM OF THE POST AS POSSIBLE TO MAKE CERTAIN THAT NO DAMAGE OCCURS. FIXING MY BOAT MAY COST $5-10,000 WHICH COULD HAVE BEEN AVOIDED IF ONLY THER HAD BEEN A HOLE!
