I have a “Drive Saver” (+/- 1” rubber or plastic spacer) between the transmission and coupler flange on the propeller shaft. Question... should the engine be aligned with or without the Drive Saver in place? I can align the mess without the drive saver... but who's to say the drive saver is the same thickness all the way around when I install? I am thinking of just removing the Drive Saver and ending the discussion (boat came with drive saver). I have a Yanmar 2GMFW. What say you?
