C
Calvin
This afternoon while sailing my 1999 H260 off the wind in about 15 knots of wind a sound somewhat like a gunshot signaled the snapping of the 1/2 inch stainless steel bolt on which the rudder pivots. After getting the sails down I jumped into the water - thank goodness that in Ga the water is still warm - to retrieve the rudder which was still attached to the boat by the lifting and lowering line. Since I have read several times on this forum that this rudder floats I did not think anything about cutting that line so I would be able to put the rudder in the boat. Well quys, guess what, the rudder, at least my edition of it, does not float. As soon as I cut the line it disappeared into 60 or more feet of lake water. What had started out as a troubling inconvience has now turned into a major problem which will probably be expensive. If you have a 260, I advise you to check the condition of the rudder bolt. I did retrieve the bolt and it appears to me that it may have been defective. This is something I will have to take up with Hunter. I just can't believe that enough pressure would ever be generated by the rudder to break a bolt of that dimension. Has this happened to anyone else? Aside from all this, I really feel stupid because my wife told me not to cut the line but I told her that the rudder floats so it wouldn't be a problem.
