My motor mounts are bent
Jim,I have been worried about my motor mounts bending since last year. I always take my motor off when trailering any more than a very short distance. So it is definitely not due to trailering in my case. As soon as I saw your posting, I called Hunter and asked for them to send me heavier ones too. They said that after you reported the problem, they weren't able to come up with a way to make them stronger. Apparently, there have not been many complaints about the brackets bending. They told me they would be happy to send me another set of brackets to replace my bent ones. I accepted their offer and plan to take the replacements to an aluminum welding shop to beef up their design myself. I will then replace them next time I pull the boat out of its slip, probably in November. It is my guess that this problem is developing primarily on 260s that are using 4-stroke engines that are so much heavier than the two stroke engines of earlier years. If I remember currectly, you have the same engine as mine with that heavier bigfoot lower unit. Let's stay in touch on this item.Bernie
