Hello,
Hoping another Alden owner can share any relevant experience with this issue for similar construction details. Wind Song is a 1965 European constructed Caravelle. Last year, I had the fuel tank opened and mucked out as a preventative maintenance activity. Who knows how long it had been, internals were in good shape, minimal muck. A new “tank top” was fabricated and bolted down, as the previous one was a bit deteriorated. However, quite a bit of water in the tank end of season, we believe some water leaked into the tank from the tank top last season, as the surface is very uneven between studs. Leaking stern tube, being replaced this year... The construction detail appears as to be a mild steel frame, with the threaded studs attached, which is glassed in around the perimeter of the tank.
We think the mild steel is starting to corrode and swell, making for a very uneven surface between studs, and now difficult to seal, even with an adequate gasket. It is hard to see in these pictures but wanted to provide some background.
Has anyone else had similar experiences, how did you resolve? Trying to avoid a major job extricating the mild steel frame for time being….?
Thanks TaborKP
Thanks TaborKP
