C
Claude Labrecque
We have purchased a used 1991 Legend 35.5 this summer. Our first sailboat. We are very satisfied with the performances and the equipment, except for one problem that we can not solve.When our Autohelm 4000 Autopilot is engage and our Alden Barbor Super cold machine is starting it's cooling cycle, the Autohelm display start flashing, show the number 4001 and the autopilot disengage itself. The pilot is now in Stand by mode. One push on the Auto button will set the Autopilot back on track for anywhere from 15 to 25 minutes, until the Alden Barbor start a new cooling cycle. It took us several weeks to find out what was the problem with the Autopilot, but finally made the association with the fridge.When the Alden Barbor is in function, it draw 8.5 amps on the amp meter on the circuit breaker panel. The manual say it should be closer to 6 amps when running.My electrical expertise is minimal but I have checked the wiring for size and all connections, everything is OK. Electronic and Fridge are on separate and distant cuircuit breakers in the panel. House battery are new (4 group 31 with more than 450 amps) and this situation occurs even if batteries are fully charged.Any help would be greatly apreciated.
