Alcohol stove pressure
Jay
I have an '84 C30 with an old alcohol stove. I live aboard and the stove is in good shape. The previous owner replaced the alcohol tank with an air tank, the tank I believe is fine. I'm losing pressure somewhere in the line causing my stove to die. The first thing I plan on doing is replacing the hose and the fittings because I obviously have a leak somewhere. Is the propane conversion hard to accomplish or is it simply a propane tank with new hose and fitting?
Jay
Nov 12, 2006
256
Catalina 36 Bainbridge Island
Pressure
Do you pressurize the tank (like with a hand pump)? If you are losing pressure I would first suspect the tank. If you had a leak between the tank, and the stove you would have alcohol spilling out somewhere. You can't convert the alcohol stove to propane. You will need to install a new propane stove, along with the tank, hose, regulator, compartment for the tank, solenoid, etc.!
Nov 12, 2006
256
Pressure
Jay
pressurized
Hey Mick, the tank had pressure to it and when I pulled the tank out to check it, the fitting was leaking on the tank. I found liquid behind the stove also, my first plan is to replace the hose and 20 year old fittings first, then go to plan b if that doesn't work.
Jay
pressurized
Jun 2, 2004
1,438
Oday 25 pittsburgh
Throw it away and buy a safe stove.
Origio http://www.swego.com/stoves_alcohol.htm makes safe stoves. Pick one, then shop it then click the chandlery here and ask if they can get it for you.Click the related link. r.w.landau Edited: no one stands behind their stuff like SBO.
Jun 2, 2004
1,438
Oday 25 pittsburgh
