Alarm and warning light not coming on
Aug 27, 2012
98
Hunter 1990 Hunter 35.5 Toronto
Recently I turn the key and I am not getting the buzzer or light coming on. We played with it a bit and flicking the toggle switch up it some times sounds We we’re thinking that maybe it’s the toggle switch Any experience with this
Thanks Floyd
Apr 12, 2007
65
Hunter H49 la romana dominican republic
In my case was the little speaker of buzzer that died (but that was a lighting striking so most of the electronics were also dead..)
May 24, 2004
7,179
CC 30 South Florida
Intermittent electrical problems are frequently traced to frayed wiring or loose connections. Take a multimeter and check for continuity of the wiring in the harness that goes from engine to control panel. Also check the pin connectors.
Feb 23, 2018
52
Hunter 356 Marseille
I had this problem too on my 356. I found a corroded block connecter behind the rear cabin before going upto the ignition key
