Airmar P79 in-hull depth sounder
Hunter 28.5 Williamsburg VA
I have an inhull Airmar P79 sounder. Some times it does not work. Usually just after a haul up bottom job. Wonder if anyone experienced similar problems and know the fixes. Thanks
Feb 1, 2015
22
Hunter 33 Portland, or
I just replaced my speed transducer that refused to talk to my Seatalk ng nework is just installed. It is a st800 by airmar. I just unscrewed it and had plug ready to go and a bit of water came in until plug seated (maybe a cup). Then I cut the wire at old transducer and taped connection end of new wire to it and pulled the old wire with new wire attached through aft cabin bulkhead. When new wire was through conduit I removed plug and installed new fitting into thru hull fitting. Went pretty easy.
