Bob Knott
Peggy,I read someone elses post where you said that flowback into the bowl after flushing could be a partially clogged vent line. Assuming no easy access to the vent except from the outside how would I clean the vent line out. I would fear a coat hanger would be too rough and not bend enough, and it wouldn't seem that compressed air would help much since the vent has the cover to deflect water away from it which also prevents easy access.Thanks for your thoughts.Peggy , I just finished reading your forum archive on cleaning the vent line and now see you recommend water, but the cover on the vent line that prevents water from entering when heeled over during sailing would seem to prevent easy access for the water flow. I'll give it a try today and see what happens.Bob Knotth380
