air or airless sprayer?
C
Chris
Hello all: I'm going to paint my boat (topside) and I thought using a compressor/sprayer would be the cleanest and quickest way to go. However, I've heard differing opinions on which kind of spraying method to use, i.e. mixing with air or without air. I'm using Brightside one step polyurethane. Anyone out there know the best way to spray? Chris.
G
Gary Clarke
To air - or not to air ? That is the question.
How experienced are you with either machine? The forte of an airless system is that there is almost no overspray. That's good ! But an airless gun can not easily feather the paint, the trigger is either totally on at about 1500 lbs of pressure, or totally off...nothing in between. The airless is a machine that delivers anywhere from 1/2 to three gallons per minute. Think about that...thats a lot of paint in a short period of time. That being the case if I were to paint my boat with an airless I would use a tip no larger than 11-12 thousandth in size, that would reduce the flow to a manageable rate. I would shoot with the gun about 14-20 inches from the surface. With a conventional air system, you will use about 50-60 lbs of air presuure and will apply the paint in a more controlled manner. you can adjust the width of the fan...more control, and you can lower the air pressure as long as you still have good atomization, that's good. With the air system you will use less paint and have considerably more control....so unless you have considerable experience in airless, you should probably stay away from it. Use either air system or the newer HVLP systems that you can learn about and rent at your local automotive paint store. Oh P.S. Airless systems are somewhat dangerous, in that if you accidently spray your hand, arm or finger from as little as 2-6 -nches away... there is so much pressure that the paint will be injected into your skin, and that limb could have to be amputated......convinced ?
C
Chris
Thanks, I'll go the air
Thanks to you Mr. Clarke: After reading your helpful note and researching a little more I've concluded to rent a system that can mix with air. Thanks again...
Dave
Airless is for Houses
We use airless guns for construction. A really fine tip can be used to shoot lacquers and other fine materials. All automotive type applications including aviation, marine and industrial painting uses the "pot gun" where you can adjust the air and the spray pattern to get a fine finish. A little practice and you can match the finish on a car. I did a tool box once for a truck and it looked exactly like the GM finish. Good luck.
