Jim
I have just changed the anti-freeze in my 1984 2GM Yanmar and seem to have an air lock in the cooling system. I do have a heat exchanger for the water heater. The engine gets hot. I noticed a plug with an allen wrench insert on the water pump. Can this be removed to bleed the system of air? It looks like the plug has never been removed and I would imagine it would be very tight. I have filled the hoses to the water heater but that didn't help. Also the hoses are not getting hot and neither is the coolant in the engine heat exchanger. I have seen some similar stories in the archives for other engines but not the 2GM engine. How do I get the air out?
