A
Alan Eland
Gordon,My '89 Hunter 30 has a Yanmar 2GM20(F). I changed the fuel filter element yesterday and made the mistake of not filling the filter "cup" with diesal before reinstalling and starting the engine(the cup has since been filled). I did bleed the air from the bolt on top of the filter. But, as you can probably guess, the engine started briefly and then stopped. Attempts to restart have only served to drain the batteries! After talking with some guys at the marina it appear that I have air between the filter and injection pump. Is there an easy way to bleed these lines? Do I only have to worry about bleeding the line between the filter and injection pump or could air have gone beyond this line and into the pump? Timing is everything. I have a trip scheduled to Block Island tomorrow morning. I'll be trying to bleed the line tonight after work.Thanks in advance.Alan
