air in fuel line
impy
Jun 10, 2009
1
hunter 22 antiposion creek VA
New owner for 1997 Hunter Passage. Problem I am having is when I am out in rough weather and need to drop sail to enter a harbor. I start the diesel and proceed to drop sails. Furred jib and start dropping main when engine cuts out. Engine runs me out of slip fine but this is the:confused: second time engine has cut out in bad weather. Could this be a problem in the tank pickup or a sign of an air leak in the fuel line?
Jan 8, 2007
8
Hunter 37.5 New Bern. N.C.
Air in Fuel
Sounds like bad weather is mixing up crud in fuel tank blocking pick up tube or fouling filter. If If you have a screen at bottom of fuel pick and if you can remove it. Check fuel filter and change if necessary. Happy Sailing
Mar 25, 2010
152
Hunter 34 Rose Haven MD
If it was air you would need to bleed the fuel system both high and low pressure sides before it would start. Agree with Loco - sounds like crud in the fuel blocking the pickup tube screen.
Dec 2, 1999
15,184
What motor do you have?
I would check that pickup tube first! If you have a Yanmar JH they are self bleeding but you could also have some sort of an air leak.
Scott
Sep 24, 1997
242
Hunter 31_83-87 Middle River, Md
What was the fuel level in your tank? After having a similar situation, I have never allowed my fuel tank go below 1/2. Never had a problem again. My motto: "KISS - keep it simple stupid." If that doens't work, go sequentially for the more complex.
