With the hot weather in Wisconsin, my air unit is pumping out a couple gallons of condensate a day, right into the bilge. Has anyone ever, or what is the opinion on the following modification: My air unit is mounted high on the port side of the back compartment. It is actually high enough that I am considering re-routing the condensate hose, adding a fitting into the spare propane locker, and letting the unit drain there, and out the drain from that locker? I have thought safety, and there is never a connection in that locker, it is only used to store a sealed propane tank, and the condensate drain would be high vs. the bottom locker drain. Any comments or ideas, since when I don’t run the air, the bilge is dry, dry. Also, anyone ever added another lumber hole in the first, (aft section of the main bilge) to allow water to flow to the section with the pump? That 4” step is kind of a bad design issue.
Thanks in advance for your comments…
