AC on my 340 similar
Norm,What I plan to do on my 340 would be adequate for your 35.5. I recommend you search the archives there is lots there.I recently purchased al of the materials necessary to install air conditioning with reverse cycle heat. It is a 16,000 BTU unit made my Mermaid and I plan to install it myself this fall. The unit comes with most everything you need to install it. 16,000 BTU is the largest unit you can run on 30 A shore power and should be adequate for your 340 in the NE. As far as placement goes, there are drawings that should have come with your 340 showing general ductwork layout and location of the compressor / exchanger. I would suggest you look an another 340 with AC already installed in order to get an understanding of where everything goes. As far as installing it yourself, it take about 40 hours if you have all of the necessary tools such as 4 and 6 inch hole saw and good mechanical and electrical skills. I am installing the seawater pump and strainer in the bilge area. I installed the required thru-hull last year when the boat was hauled out. Marine Air also makes a good unit and many Hunters have that as original equipment. They have a great web site with lots of good information and installation suggestions. Good luck with whatever you do. The 340 is designed to have the main cabin supply vent and the thermostat control in the hanging locker above the nav station, the forward V-berth supply vent in the hanging locker on the starboard side and the aft cabin supply vent in the wet hanging locker in the head. The return air is via a vent into the setee where the compressor unit is installed. The evaporator/compressor/exchanger is mounted under the starboard setee where you sit when at the nav station. Hope this helps. I have mixed feelings about hauling around all that stuff but the Admiral will enjoy the boat on the hot humid July and August days when there is no wind and too hot to sail. 16,000 BTU is adequate for here in North Carolina where in is hotter and more humid than where you are. There are things you can do to improve the cooling efficience like covering hatches and the windshield with an insulated cover to reduce heat ingress. Hope this information helps.
