Air conditioner water pump
324
Catalina 320 Gulfport, Fl
Mine died...I've not had a lot of experience with marine AC. Which water pump do you like and which will last more than one or two seasons. Your opinoins are appreciated. Thanks
Sep 6, 2007
324
7,351
Alden 50 Sarasota, Florida
March pumps
My experience is limited to one pump, that being the one which came with my MarineAir system and it literally blew apart one day for no apparent reason after only a couple of seasons. Based upon recommendations from those who do know more than me, I replaced it with an equivalent rated March pump. So far, so good...
7,351
March pumps
Aug 8, 2006
340
Catalina 34 Naples FL
ac pump replacement
I replaced mine with a little red pump called a "proven pumps" submersable pump. It was model B-500 and was $88.50 last year at the marine supply store. It is an exact replacement of what was on mine. It says TEEL pump on it model 1p808A..I could not buy from the MFR, had to go through a store. Terry
Aug 8, 2006
340
ac pump replacement
Dec 25, 2000
5,912
Hi Patrick, I'm not sure what you mean by died,...
but our original 1991 Little Giant still works great suppling raw water to both reverse cycle heat pumps. I've had to take it apart and clean the impellers from time to time, but otherwise no problems. Salt tends to accumulate around the impellers and over time will slow the pump until it stalls. If your pump has similar symptoms you might want to clean it first before replacing it. Our Little Giant motor is a sealed unit with the impeller floating on nylon bushings in the impeller housing. The first time I removed the impeller for cleaning I missed the rear bushing. It ran for a bit then stopped again. This time I removed the entire unit for cleaning and found the missing rear bushing. After I put it back together correctly this time it ran great. I too thought the pump had died, but just a simple cleaning brought it back to life. Terry
Dec 25, 2000
5,912
Sep 6, 2007
324
Thanks All
This is why I like this site so much. I really appreciate your input, I'll try cleaning it first...but you know that is a 4 letter word too...work!
Sep 6, 2007
324
Thanks All
Aug 18, 2007
28
CNSO Mikado Titusville, FL
March pumps
Are the cadillac of A/C pumps. I highly recommend the LC (liquid cooled) model. Both my A/C units use LC-3CP-MD and they are pretty bullet proof. Find out how many GPH your A/C unit requires and match up the correct model. Good deals can be found on Ebay.
Aug 18, 2007
28
March pumps
