Air Conditioner Smell
cooper
Mar 25, 2013
28
Hunter 49 Delaware
Hi, Our air conditioner unit in the fwd cabin has started to give a smell of ammonia/pee. I have emptied the drip tray and scrubbed it and used disinfectant and simply green on it. This seemed to help for a couple of hours, however, the smell returned. The intake vents are clean. The smell only happens when the a/c unit is on. Cheers
sdstef
Jan 31, 2013
140
Hunter 28 Branched Oak Lake
try to clean the evaporator coil with coil cleaner. You can get it from a wholesale hvac/ref. supply store.
Feb 26, 2009
716
Oday 30 Anchor Yacht Club, Bristol PA
White vinegar works wonders. I killed cat pee stink in a bedroom's wood floors.
Apr 11, 2010
979
Hunter 38 Whitehall MI
Check for another thread on here. We talked extensively about it.
The smell you are talking about is trimethyl amine.
It is a by product of the manufacture of the fiberglass insulation that is used. When fiberglass is under cured it will off gas formaldehyde. When over cured it will off gas trimethyl amine which is characterized by the smell of urine or dead fish. It's harmless but smells.
Humidity and temperature are triggers that will cause you to be able to smell it.
cooper
Mar 25, 2013
28
Hunter 49 Delaware
Thanks for the tip-I will hunt around and buy some coil cleaner and give it a try. We are willing to try anything as the smell is somewhat overbearing.
cooper
Mar 25, 2013
28
Hunter 49 Delaware
I have splashed some white vinegar around at the hope that it might remove the smell from the air? I went to the forum from Aug last year in regards to the trimethyl amine and this sounds very feasible as we are in Stuart FL at the moment and the humidity here would be close to 100% everyday and the temp around 90ish. Any idea how to stop the smell?
Apr 11, 2010
979
Found the previous thread
Search on
odor from rear air conditioning
And it will pop up
