Consider if you will a cruising vessel with a center cockpit and a bedroom aft. I carefully insulate that room and install a small 6000 BTU air conditioner. The draw is 4.5 amps @ 120 volts. So I need approx 50 amps per hour from a 12 volt battery bank (Losses to inverter etc). I have...say 900. I can use about half of that, so I should be able to run it continuously for 9 hours. I run this while I sleep and recharge the next day with wind, solar or an on-board generator. (I don't want to sleep with a Genny running) This would be for hot sticky nights on the hook while traveling. The boat would have a bigger AC unit for shore power but this would allow for a good nights sleep when it is nasty out there. Any thoughts?
