I have an older Cruise Air 16000 reverse cycle marine air conditioner that is starting to short cycle. Specifically, when the compressor comes on, the temperature registered by the digital readout drops 2 degrees. When the compressor shuts off, it goes up, causing it to short cycle.
The unit cools good. However, I have to run the unit at a low temp setting to prevent it from shutting off.
I installed the unit about a year ago (bought it used off of ebay) and it worked fine for the year (I live aboard and I run the unit all year). When I installed it, I put the thermal coupler in the air vent that feeds the compartment that the unit is installed in. I don't believe it is influenced by temperatures in the compartment.
If I had to guess, I would say there is a voltage drop going on in the low-voltage section of the unit. It will be a royal pain to hunt down the connection. Can anyone shed light on the problem?
