We recently replaced our batteries with 4 AGM's (105'sx4) from Sams. We have a 3.5 Kw generator. Our plan is to install a Sterling 60 amp battery charger and Victron battery monitor. We just ordered an Electromaax 140 A alternator with serpentine belt kit and external regulator with temperature compensation for battery and alternator.
Our use for the boat will be cruising in Florida and Bahamas in winter months with minimal use of marinas. Our guess is that we will use 80 to 90 Ahr per day, we have all LED cabin lights and anchor light. However we do have a large fridge and good sized freezer for this size of boat.
The general advice seems to be: go with as big a house bank as possible, and keep a small emergency start battery, but charge the AGM's to 100% as often as possible if you want them to last.
I am thinking about adding more AGM batteries and about 280 watts of solar panels above the bimini on the Hunter arch.
The advice I need (if all of the above makes sense) is how big should the battery bank be ?
If AGM's need to charged up to 100% is it better to have them divided into two smaller banks rather than one really big one. When one bank gets down 50%, I would bring it back with the alternator or battery charger until the acceptance drops then let the bank come up to 100% on solar while living on the other bank. I have no idea if this is practical with 280 watt of panels ?
I suppose with two smaller battery banks used this way I would need the double bank battery monitor as well to see when I get back to 100% with the panels and can then switch banks ?
any advice would be appreciated ! Bob
