I have replaced the wet cell battery which came with my H260 with a 95AH AGM battery, and I am wondering if it will be enough to power a 10A CD/Receiver, Raymarine autopilot(10A), Raymarine Depth/knotmeter, VHF and start the outboard(Nissan 9.9 4) 2-3x. We typically sail for about 3-6 hours(on a a good day). If I get a second battery, should I use it in parallel with the existing to increase the capacity, or opt for a dedicated starting battery? I would probably place it in the aft port bulkhead to simplify wiring and because their's a flat panel ready and waiting for a battery and strap.Also, I have a Unisolar 5W solar charger. Can I use this to recharge the battery without worrying about overcharging? Or should I get a regulator? West has a cheap one for around $30, and then they jump to $80 and then up. Any recommendations?I usually get down to the boat once a week and I'm uncomfortable leaving a shore powered 3-stage charger plugged in when I'm away.Thanks,Al
