Hi everybody --
I'm working on making some repairs to an O'day 22 that I'm going to be using as a daysailor. I noticed that the thru-hull fitting in the aft of the boat had failed (the outer piece had popped off) so I tried to set about removing it to replace it today. However, I wasn't working long before I realized that I couldn't access the inner part of the hull to thread the fitting in. It's behind the cockpit area and the only way I think you could get near it is by going through the starboard lazarette, and it's way too tight quarters for me to get in there.
I'd hate to have to cut into the back of the cockpit to try and get at the inside of the boat. Does anyone have any clever ideas?
I was thinking I could try to seal a smaller size thru-hull into the existing one, but that would reduce the flow and there wouldn't be the threaded backing securing it to the hull, so that's probably not the best idea...
Is this the kind of thing a boat yard could do a lot easier?
