Looking for assistance with a leak that has developed in my aft shower stall. When the aft shower is used I've noticed that there is water leaking into the aft cabin. The leak is slightly above the cabin sole level - seemingly on the level where the shower wall intersects the shower tub/pan. The leak is exactly on the corner of the shower stall/aft cabin wall. On the interior, there is a vertical seam that connects the aft shower wall with the port (interior) shower wall. I assume that the water is making it's way through the vertical seam and down the outside of the fiberglass/plastic shower stall into the wood veneer and down onto the cabin sole. Has anyone had this problem? If so, how have you addressed it? Caulk of the vertical seam, or have I missed another possible location for the leak?
Thanks.
Thanks.
